got the whole motor put back together with the help of MY DAD, CHARLIE, AND MY BROTHER. and now i need to prime it before i start it obviously. the spark plugs arent in right now/ coils not hooked up.. so i need some tips on how everyone has primed their motors before. i've been told to unscrew the oil pressure sending unit. leave the spark plugs out but connect the battery and turn the motor until oil comes out of the hold for the pressure sending unit. then i'm good. any other tips??
ADVICE..on how to prime the motor..
DOn't unscrew the sending unit unless you want a big oilly mess that accoplishes nothing.
Pull the spark plugs, leave the Harness form the Ignition module (the thing under the coils) unpluged, and crank the engine over with you footto the floor (over 80% throttle while cranking = flood clear mode, no fuel).-6S Resident Mechanical Forensics member #001.
carry this conversation onto the post MUTHER FUCK SHIT DAMN[email protected]%k you and the horse you rode in on
i've heard squirtin a little oil in each cylinder also helps before initial start.VTEC is like having turbo lag but without the turbo. Its like waiting for bad sex.<br />...<br />1993 SC2m- sold<br />1996 Jeep Cherokee- Likes to get dirty<br />1974 AMC Javelin-Underfunded Project Car<br />2007 Kawasaki Ninja 650- Keep the shiny side up.
keep the coil packs unplugged, and crank here over a few times with your foot to the floor. Then, plug in the coil packs and fire it up. let it idle a little bit, and go seat those rings (after engine is to temp)LSJ powered 1998 Chevy S-10 turbo
Originally posted by Green Monstahkeep the coil packs unplugged, and crank here over a few times with your foot to the floor. Then, plug in the coil packs and fire it up. let it idle a little bit, and go seat those rings (after engine is to temp)Ian---The Fat Ass
If you mash the gas like sam said the car automatically in the pcm disengages the injectors. Really cool is what I thought when I first read that. No fuel and no spark='s less worry about problems. But yeah like jay said seat them bitches right.2002 Saturn SL1- 5 speed, basic, slow, and staying that way.
