I'm rebuilding my 2002 Saturn SC2 engine and I need to know if my Pistons are properly facing the correct direction I need to know if the circled protrusions should be facing to the left or to the right
2002 saturn sc2 engine rebuild
Per FSM:
"Assemble piston and connecting rod:
Important
It is standard practice to assemble the piston and connecting rod with bearing tang slots in the rod directed toward the exhaust manifold side.
Align the mark on top of the piston with the front of the engine. Assemble the connecting rod to the piston with the bearing tang slots directed toward the exhaust manifold side.
Also per FSM:
Verify the proper piston pin orientations by looking at the underside of the pistons. Ensure the piston pin boss with the rectangular-shape casting feature is pointing toward the back of the engine.
🥰 1
Say I've got an SL1 3rd gen manual and I want to do an engine swap/probably tranny swap from a 3rd gen manual sl2. Whole car would be available to me,...
Channel: 6S FB Group
12-09-2019, 04:53 PM -
Well Suicide'$ fuel lines are put together just need to tighten the fittings, these are ptfe 6 an fuel lines, finally decided on this cars name and came...
07-14-2022, 10:59 AM -
Rattlecan tip:
Spraycan paint directions say the lowest application temperature is 50 degrees, however, paint can be applied...-
12-18-2020, 03:28 PM -
Anyone have a 1st gen twin cam timing chain cover theyd sell. Mine was previously welded and starting to crack . Would need to be shipped to 55421 Pfa....
07-11-2020, 05:42 PM -
Need help , car was jumped yesterday , saw sparks from the battery area because guy jumping was also trying to test battery at same time , now car has...
06-03-2021, 09:24 PM -
