2002 SC2 multiple CEL codes, crank but no start
  • 2002 SC2 multiple CEL codes, crank but no start
    I'm going to start with this car has not run since summer of 2010. When I first brought the car home from my parents house and started into it, I knew that it needed a fuel pump and a new battery. I replaced both items and after the car would start, sputter a few times and then stall out. After I plugged into the computer and pulled codes it has stopped doing anything but crank with no start. I do not know where to start with my diagnosis which is why I'm here. The 4 codes that I have on the computer are as follows:
    P0232 - Fuel pump relay control circuit high voltage
    P0413 - Air injection reaction switching valve 1 circuit open
    P0637 - Power steering control circuit high
    P1583 - Cruise control direction circuit high voltage
    I will say that prior to the car not being touched I had removed the power steering system and the secondary air pump, so I'm sure that's where those codes are coming from but I don't remember getting the power steering code from my 1997 SL2 when I removed the power steering. I have posted everything listed not knowing if they are related or not.
    I will be grateful for any and all help!
    A good Saturn is a good sleeper - J. Beanan
    97 SL2m - RIP: everything transferred it all to the '02
    02 SC2m - Father's Memorial project car
    Daily - 05 Chevy Silverado 2500HD 6.6 Duramx/Allison
    -5" turbo back exhaust and drop in K&N filter, otherwise stock...for now
    I'm not an expert with 3rd gen but I'll try.
    the last 3 codes really don't matter. It's interesting they all are high though.
    the fuel pump is likely the problem code to chase. Are you getting fuel pressure in the rail?
      I did recently change the fuel pump as it was previously an issue but I never rechecked pressure after replacement. I should know better and have checked that already.
      I will find my test kit and check it tomorrow and report back.
        So after the last month and a half of crazy OT at my main job and several extra shifts at my 2nd job, I found some time to go through the car a little better to figure out what's going on...and I can't believe the rookie mistake I made!
        So I checked the fuel pressure at the rail and found I had zero move on the needle, at which point I check the fuse which was good, only to discover at some point years ago I pulled the fuel pump relay (probably to help diagnose the bad fuel pump) and never replaced it. I put a relay in and the car fired without issue. Thank you ZombieSatty for helping me with a direction to start.
