I’ve got a 2002 SC2 that’s cranking, but won’t start. I drove it to the store and back one night and then it sat for two days. When I went to start it after that is when the issue occurred. It’s never has issues with starting before. We’ve got spark, fuel, and compression. It’s got a new ects and the security light isn’t on. We did get it to start a few days ago and for the rest of the night it would fire right back up. But the next day we were back to the same issue. I have no clue what to try next. Any help is greatly appreciated!
2002 SC2 crank, no start
Could be one or more of these. start with the cheapest
Fuel tank empty?
Battery Weak?
Battery connections loose or corroded?
leaking fuel injectors?
Bad fuel pump?
Bad Pressure regulator?
Ignition components wet/ loose?
Loose or broken wiring in the starter system?
Bad Coil?
engine coolant sensor defective?
Crank position sensor defective?
If you have a mind to check the coils and mounting clean up mounting bolts and area touching the bottom
2002 Saturn SC1, Metallic Orange , L24 EFI 1.9 , 213,883 miles
I know nothing about Gen 3 security. So hopefully it's not that.
What doesn't make sense is you say you have fuel, spark, and compression. You should get something, like it is trying to run, but I am inferring you have no sign of life.
How do you know it's not fuel? Did you check the pressure? Did you squirt fuel in the manifold? Did you listen for the pump to run?
How about compression? Check all 4 cylinders with a gauge? Although unless all 4 cylinders were blown you would expect some sign of life.
How did you check for spark? The CPS is one possible culprit, but that usually fails hot. Not your case.
Did you replace your ECTS sensor recently? Any chance the connector is bad? I had to replace mine in the '98 due to corrosion.
Do you have live data to look at RPM or fuel when you crank? If not consider buying one of these. They are awesome.
'99 SL2, 5SP bought new
Rebuilt at 204,067 September 2017
Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on!
'98 SC2, 5SP bought 2018
I have a 2002 SL2 that I've been driving since 2001. Made some minor modifications, simple things even I can do like air intake, header exhaust, performance...
Channel: Saturn Technical & Troubleshooting
01-21-2020, 12:40 PM -
After a long 15 years; I have decided to get the first car I ever owned. The first car I ever purchased with my own money right out of HS.
Back...-
Channel: What's Going On?
06-30-2021, 01:05 AM -
Hello new to the Saturn world here! I just got an amazingly clean 2009 Saturn with the 2.4 ecotech! It has a code for p0171 and runs slightly roughish...
Channel: Ecotec and Beyond
02-24-2020, 09:00 PM -
Hi.......
My name is Dana, and I inherited a Saturn.....
LOL! Ok, I meant to share my personal post here back when I joined,...-
Channel: 6S FB Group
02-16-2021, 11:38 PM -
After some time with the RHDSL1 ( https://forum.sixthsphere.com/forum/...s/48099-rhdsl1 ) I've decided to build a RHDSC2 instead. The RHDSL1 was actually...
Channel: Member's Saturn Project Builds
11-22-2019, 10:11 PM -
