I've got a question, when you wen't from drum brakes to disc's on the rear, did you have to add a prop valve for the brakes, upgrade to a different master cylinder, did you have to make any brake sys tem moddifications? The only reason I'm asking is I'm converting my 66 GMC truck from drums to disc's and I having to upgrade master cylinders, prop valves, along w/ spindles in the front, so I was just curious.
Thanks Tony
Thanks Tony
