Link: http://scca.com/_FileLibrary/File/2007SoloRules.pdf
An item I found interesting......
"The following allowances apply to strut-type suspensions. Adjustable
camber plates may be installed at the top of the strut and
the original upper mounting holes may be slotted. The drilling of
holes in order to perform the installation is permitted. The center
clearance hole may not be modified. Any type of bearing or bushing
may be used in the adjustable camber plate attachment to the
strut. The installation may incorporate an alternate upper spring
perch/seat and/or mounting block (bearing mount). Any ride
height change resulting from installation of camber plates is allowed.
Caster changes resulting from the use of camber plates
are permitted."
are permitted."
