Front motor mount
  • Front motor mount
    Mostly to Vinny, but....
    I went out on my lunch break and looked at the mount, the one that bolts to the bell housing w/ 3 bolts and to the support member, I took pictures but I can't upload them till I get home tonight, but the mount is comprissed of 2 steel supports off of the front support, and an entirely plastic honeycomb styled housing with a steel drum that the rubber mount w/ bolt shank is preesed into it.
    The mount materieal is very similar in tactial sensation to my r/c car compents that are plastic infused with carbon fiber, and they look about the same.
    and how do you add pic's to your post?
    Tony
    06' Ion 2
    09' WRX
    ...The distinction between past, present, and future is only a stubbornly persistent illusion... Einstein
    use tags with the picture's URL between them
    did you use a camera phone? I'll give you my # to send it to me
      camera phone, I don't have one of those, I got a digital camera, but I can't hook it up here at the hospital, that why I have to wait till I get off work. sorry Vinny
      06' Ion 2
      09' WRX
        http://www.sixthsphere.com/forum2/garag ... mod&id=839
        http://www.sixthsphere.com/forum2/garag ... mod&id=841
        theres a couple of pics, if you want a couple more let me know but hope this help the solving of the issue, if they don't work there also in my gallery
        Tony
        06' Ion 2
        09' WRX
          ah son of a bitch why did they have to change that [img]{SMILIES_PATH}/mad.gif[/img]
          the one in the 03-04 looks like this (after being filled mind you):
          now, if you have the same mounting points as that turd, then you should also be able to use the old style.
          OR
          I could fill that style, but I have no idea how the casing would hold up to the added stress
            that was my next question.... would you even want to try to fill one? is the integrty their? and do you think that the mount would really hold up to continual stress?
            06' Ion 2
            09' WRX
              well, if it's still empty from the side in the center section as these are, then yeah you still would want to fill it
              now as far as the structure enduring the addes stress, you'd assume that if they switched designs that it was able to take the same pressure levels, but I'm not so sure. I'd have to check it out hands on to get more of a grasp of how strong it actually is
                fyi....... i talked to tim and the 05's are also the composite materieal.
                jeez go figure, they just van't leave shit alone!!
                06' Ion 2
                09' WRX
                  This is why I'm talking to that guy from the RL forums. To get some decent mounts to replace that crap.
                    well the one in my picture is listed as a replacement for the mount you both have. if one wanted, and the bolt-up points are the same (which it really looks to be), you could put one of those in it's place. it's like 60 bucks too so not too bad. I'm thinking though that the plastc crap might be able to take it, I'm going to check ace's whenever he comes by and take a look. if one of you guys would want to test it for me for the cost of shipping maybe we could work it out.
                      After spending a good 1/2 hour looking at it last nightI really couldn't justify spending the money on filler materials. The shits plastic, who in there right fucking mind make a motor mount out of plastic????? If I do anything for now I'll go get a 03-04 mount and then I'll think about filling it, next time you get a chance could you verify that the mounts are in the same locals betewn 04-05 that way I dont waste any money one one, Thanks
                      Tony
                      06' Ion 2
                      09' WRX
                        yeah no problem Tony, I plan on it soon.
                        I actually have to take a look at mine anyway, I'm getting noise again up front, one of the bolts must have backed itself out a bit, just not sure which one.
                          when you get a chance and look at the new mount let me know what you think, i'm curious. thanks for the help Vinny!!
                          Tony
                          06' Ion 2
                          09' WRX
