ok so i am looking to run a 3" downpipe on my 94 sc2....it seems that fitment is going to be very tight between the block and the subframe...how hard is it to make this fit and for that matter not make it smack against the block or subframe....thanks
3" downpipe?
Re: 3" downpipe?
Originally posted by turbosc2ok so i am looking to run a 3" downpipe on my 94 sc2....it seems that fitment is going to be very tight between the block and the subframe...how hard is it to make this fit and for that matter not make it smack against the block or subframe....thanks- Justin [s]99 Blue SL2 - T3/T4 14psi[/s] (dead)
http://qksltwo.com/turbo/build06/build06.html
First picture is the new brace he setup, to give you an idea.
Originally posted by Brandon94sc2Dont the down pipes that come with the Alpha kits fit between there with no problem and are of the 3" variety? If anything just bend the cross bar enough to clear the downpipe. but make sure you bend it enough so when the engine moves around its still not going to slam into the cross member.
it also depends on whos making it. that has a lot to do with it. if your doing it yourself and you havn't done it before, just make sure to buy an extra 3" 180. don't be scared to trash some material in order to get a better fitting finished product.
