pistons and valves
  • pistons and valves
    I got 95 dished sohc pistons ,
    95 dished valves, and
    93 flat valves,
    Should I go with the flat valves, or lower the compression even more with the dished valves?
    What would the static ratos be for those?
    I dont plan on anybig boost psi's [email protected] mabye 230hp once I get my MS.
    90' Talon AWD,TSI, Holset HY-35.
    having dished valves will not make any signifigant differance from the flat ones so i would just get better flat faced valves
      Flat valves seem to work best. I've burned my fair share of dished valves with nitrous.
      - Jeff Silva
      2001 Chevrolet Tahoe Z71 5.3L, Blackbear tune, cranked keys, e-fans, Android head unit
      1997 Dodge Caravan SE 3.3L V6 family hauler
      Vacancy here, need project car
        Its all in how the valve gets seated. A wider seat helps cool the edge of the valve.
        For your power goals I would use a 9.5:1 piston and the flat valves. With proper tunign it won't detonate, and the little bump in compression will help keep throttle response and off boost power up.
