ok... i heard that u need a blowout valve to run a turbo setup. if that's true then why don't cars that come wit a factory turbo have them? or do they have them but it's junk. sorry if i'm askin' a dumb question. i've read a lot and i'm still pretty confizzled.
blowout valve question
Factory cars have what is can a recirculating valve. Itstead of blowing the pressure to that atomosphere and making the Phhsst noise, the air gets routed back before the turbo but after the air filter. Dumping the rpressure there quites the noise down and lets the turbo just "recirculate" the air untill you hit the throttle agian.
Might I suggest to you "Maximum Boost" by : Corky Bell. Its soud explain all this "newb" stuff to you, or anyone else looking into turbocharging there car.-6S Resident Mechanical Forensics member #001.
+1 and once you get through that http://www.qksltwo.com is a good place for specific info[color=red]-Tyler[/color]<br /><br />2005 Chevy Trailblazer<br />1999 Saturn SL2<br />2002 Suzuki Bandit 1200
Originally posted by sl2fast+1 and once you get through that http://www.qksltwo.com is a good place for specific info
not to get off topic, but this reminds me of one time where a local told me you couldnt run a wastegate and a blow off valve because they get in the way of each other. At the time, about 5 months ago, I wasnt sure if he was right or not, but If I knew what I do now, I tihnk I would have kicked him in the nuts.
no, a wastegate has to do with diverting the flow of exhaust away from the turbine wheel, where as a blow off valve is there to relieve pressure between the compressor and the throttle plate when it closes. when the plate closes, a wave of pressure travels back toward teh compressor wheel. a wastegate isn't going to do shit for that, you need a valve to relieve pressure so it doesn't cause surge. I think this is why sam had mentioned mounting the BOV as close to the throttle plate as possible, to catch the wave early before it can travel far? though i may be wrong in that logic.
Originally posted by Schizzo97SC2no, a wastegate has to do with diverting the flow of exhaust away from the turbine wheel
Originally posted by Schizzo97SC2where as a blow off valve is there to relieve pressure between the compressor and the throttle plate when it closes. when the plate closes, a wave of pressure travels back toward teh compressor wheel.
Each one deals with a different side of the of the turbo if you want to think of it that way... Wastegate = turbine side and controls boost. Blow off valve = compressor side and prevents compressor surge.
Joe1993 VR R1- 405 whp/330 ft/lbs tq (my toy)<br />1993 Saturn SLx turbo (my other toy)<br />2008 PPW 350z with an Amuse kit and a lot of other stuff (my 3rd toy)<br />2006 Evo IX MR SE intake, exhaust... (my DD)
lol His posts were making my head hurt, so I figured we needed to walk through the "its understood" things.
