injectors Will these work
  • injectors Will these work
    here you go I found these. I just want to know if they work with are SATURN'S [img]{SMILIES_PATH}/smile.gif[/img]
    http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEBI%3AIT
    &quot;Brother hood is all you need in life&quot;<br /> &quot;Never Forget are Fallin Brothers&quot;&quot; <br /> &quot;FDNY 343&quot;
    No
      I thought those where the ones that fit Saturn?
        Try accle high impedacne injecotr on youru car. I ran them for many-a-moon.
          Originally posted by TURRRBOOO
          No
          +1
          those will not fit a saturn. you need something like this...........
          yeah accels seem to work good. put them in my friends eclipse gs with an hrc turbo kit. since it is a gs, it has the chrysler motor so it has the "american" o-rings, large ones. injectors are 30lbs, will work in a saturn too, but need a management system to make them work properly.
            Correct me if I am wrong, high impedance = OBDI / Low impedance = OBDII
            Been a while since I bought mine.
            T.
            Turbo SL2 with all the fixins. Fa$t A$$ Car!
              T.
              96 and newer use high
                So it's OBDI=low impedance /OBDII=High impedance.
                Thx!
                T.
                  Yes, but you can use the highs on the OBD1. YOu CAN"T use the lows on OBD2, bad stuff happens.
                  If you use an hihg resistance injector on OBD1, go up to the about 2lbs/hour flow rate over what you looked at in a low resitance injector.
                    Good info!! Thank you.
                    T.
