If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Welcome to Sixthsphere. Images and some forums are hidden to non registered members. Registration only takes a minute so please join in the community and share in the knowledge!
sorry man, I had to go to Nashville last night,lol. I thought the Tach signal was putple....... um you may have an off year like my ground was, try J1pin46, since you have been messing around some. Is your PCM under the hood or dash? Also you have to set it to 12cyl I think, it has been so long since I set mine. Another good idea would be to PM Alan "sprint" on another forum, I haven't seen him around lately, he is the one who did all the research
he is SaturnFans and he is on here, but I haven't seen him on here lately, he may be on PR too
Gree Wire on SAFC
96 - 99 Saturn J2 - B7 (White)
00 - 02 Saturn J1 - Pin 46 (White)
You mave have an off model, but I think you should run through your settings agai to make sure. Also check the fitting is tight/connected.
