afc-neo (updated with pics. Not 56K freindly)
  • afc-neo (updated with pics. Not 56K freindly)
    Look what i got!!!!
    ok well im looking for a way to mount it... but thats not my problem.
    I was looking for a sticky to install it but i dont know the wiring. Which color is what??? i know where the ECU is but the colors are..... colored diffrent. (duh) so if anyone has a diagram to wire this up youd help me out alot.
    (Vinny im getting the wideband o2 sensor in a few weeks, but i can still put this just to moniter my car until then, Right?)
    <br />tool:
    http://www.turbosaturns.net/downloads.html
    your ecu pinout should be there somewhere on that page. use that and the instructions for the unit and it should be just like wiring up a head unit.
    you can put this in, just I wouldn't make any adjustments until you get the wideband in.
      WOW, you lucky bastid. I'd have one now if I didn't have my SAFCii
        thanks :?
        <br />tool:
          I would do the wiring first. You could always use a good thickdouble back tape and scrwes to mount it.
            ^^^^^^^^^^agreed I still haven't descideed where to stick mine(safc2), I shoved it into a vent for the past 4 months
              im actually mounting it right now. It looks like its going to come out nice. im almost done but ill post pics when im done.
              <br />tool:
                So i found some plastic tabs that were about 90deg. and drilled a hole throught the middle of the AC vent base and then drilled holes on the tabs and screwed them in. Then I put a Strong Fabric Behind the Base and glued it with fabcric glue. Made a hole on the bottom left side of the fabric for the wires. Finally put velcro on the tab and the AFC. Finally..........
                It came out really nice and pressing the bottons is no problem.
                <br />tool:
                  Is ti upside down or are the Neo version with the directions on the opposite side as the previous versions?
                    From the text it almost looks like you can mount it on either of its side, and maybe set something that tells what display you want.. that'd be sweet.
                      lol i can actually put it on whatever direction i want, and change the colors of the screen and the bottons to about 6 diffrent colors. I wanted the bottons closer to me, and since the ECU is going towards the left i figured it would be better like that.
                      Ill try to make a video and play with it some.
                      <br />tool:
                        I like the turn dial thingy on the safcII, if they had a neo with safcII button layout itd be hot.
                        I also think the actual design is just too boring looking, the AFC and SAFCII have some cool little lines that make it look a bit better
                          If you are putting a AFC on your car try and mount it low, tuning mine up on the dash hurts my arms
                            very good words of insight
                              yeah my gramma and spelling are off the hook
