So far
  • So far
    Ok I want to put the nitrous in already but i know i cant do it yet. If everything goes good ill have it before christmas
    I replaced my radiator
    Replaced my IAT sensor and sensor harness
    and the next thing im going to do is change my egr valve and everything that goes along with it.
    So at the same time im trying to get everything put together for the nitrous.
    Well a question came up to me and now im just wondering about the fuel line.
    I heard i dont need to split it i can screw it to my fuel test port but i dont really know what that is...
    question is...
    is this is?
    and iv seen the wiring diagrams and some have a relay...
    will i need one too?
    <br />tool:
    You need relays, unless you want to fry your switches. Cheap at ripoffshack.
    The test valve is right where the fuel line enters the fuel rail.
    I took these for something else, but you can see the red fuel line screwed into the test port. Not sure if it's in the same spot on 1g's.
    (very far left)
      Yes, thats the test port.
        oh ok..
        yea mine looks alittle diffrent
        and its on a tube like 3 inches away from the fuel rail.
        Thanks!!!!!!
        <br />tool:
          Yep, I wasnt sure where it was when I was looking for it but a quick look in my Chiltons solved the problem.
          Make sure you take the shrader valve out before you put the line on. I bought a removal tool from a local hardware store for $1. I tried using a small pair of needle nose pliars, but to no avail.
            My nitrous kit came with a valve removal tool.
              OoOo
                OoOo
                ditto. Yeah geo, that's the test port on the 1st gens. Twist the cap off and push on the valve, just like a tire valve and if you get gas, bingo!
                  I've got a removal tool if you need when the time comes Geo
                  but then again you'd have to actually show up again to a meet or event [img]{SMILIES_PATH}/lol.gif[/img]
                    lol whens the next meet that everyone wont be drinking....
                    <underage
                    [img]{SMILIES_PATH}/confused.gif[/img]
                    <br />tool:
                      waaaaa i'm underage and I can't drink eeiiitihererrrrrr...mommy won't let me.
                        Ahh that's his choice not to drink. I'm not much a drinker myself and I have more fun being sober.
                          its just a schreador (sp??) valve, if you go to your autoparts store you can use the valve core remover tool for your tires, itll work great, and like a couple bucks at most
                            Yeah. I picked up a Snap-On core remover for like $4, so a normal on (same thing but with out the name on it [img]{SMILIES_PATH}/lol.gif[/img] ) would be like $1-$2.
