Which wire do I tap for the TPS?
  • Which wire do I tap for the TPS?
    On my 01 SC2, which wire do I tap into for the throttle position sensor?
    Got a new baby <img src="{SMILIES_PATH}/smile.gif" alt="" title="Smile" /> - 2006 Ion Redline Stage 2<br /><br />Old baby :<br />--My ride : http&#58;//www&#46;cardomain&#46;com/ride/405827
    just in you have to pull your PCM and it will be on the bigger wire thingy, which is J1 then you look for the dark blue wire in pin1 or position1
      And when you do your connection dont be cheap about it, use some good connectors that work [img]{SMILIES_PATH}/biggrin.gif[/img]
      I bought my car from a nun, made it fast and now she wants it back!
        you mean solder it, connectors are the cheap way out.
          bwahaha, it took 5 tries, but we got it!
            [quote="Schizzo97SC2"][quote="kuziken"]And when you do your connection dont be cheap about it, use some good connectors that work
              not like soldering is expensive, in fact it is pretty cheap...... It is just lazy to use connectors...
              Sometimes I Like To Pretend My Car Is Fast..
                On the S series it is the blue wire.
                I don't think using connectors is cheaper or easier they just fall apart easily.
                  Oh ok thanks, I was still wondering 3 weeks from when I posted.
                    aww cmon now he's just trying to see the for sale section!
                    lawd it's been a long time
