I have a single fogger nitrous kit for my '98 SC2 and I have a few questions. First, how much will the engine/clutch/transmission hold? My car is stock other than an intake header and exhaust system. Will I need different spark plugs? I am getting the fuel rail from a '97 and switching over to the old style fuel system, and plan on upgrading the fuel pump. I don't want to blow up my car but I want more power. I am tired of my husband outrunning me in his Honda. Any advice would be great! Thanks!
looking for advice about installing a nitrous kit on my SC2
i see its a fogger style, are we talking a wet kit? if so, a wet kit is perfect for the 98 fuel system, run the fuel line off the test port at the end of the rail. Be sure to relieve pressure and take the scrader valve out first. People run up to about a 75 shot on the engines, cluthes, thats kind fo up in the air, it will be a worthy investment to replace one, because you will shave the miles off a stock clutch. as far as plugs go, I used the ZEX plugs with GREAT sucess, most people use a 2 step colder NGK, I'm sure someone will post the part number for you. My person preference was the zex plugs, but everyone does well with NGK also.
If we are talking a dry kit, I honestly would not waste my time....... that is all
Re: looking for advice about installing a nitrous kit on my
Originally posted by redturtle98I have a single fogger nitrous kit for my '98 SC2 and I have a few questions. First, how much will the engine/clutch/transmission hold? My car is stock other than an intake header and exhaust system. Will I need different spark plugs? I am getting the fuel rail from a '97 and switching over to the old style fuel system, and plan on upgrading the fuel pump. I don't want to blow up my car but I want more power. I am tired of my husband outrunning me in his Honda. Any advice would be great! Thanks!
75 shot depending on your clutch. First before everything you should do a compression test and make sure your numbers are good and the engine is healthy.
BCPR7E11 NGK 2 Steps colder Napa part # 1283
Depending on how safe you want to be I would advise getting an RPM Activation device. This way it turns on only when your at a certain RPM, dont know what kind of kit you have or what other goodies you got. I wouldn't go cheap with the nitrous route but it's up to you. I spent around 1k on my kit and extras wouldnt have it any other way...Steven
of all the people I was hoping to see this thread, sc2grndsp and Nyce are two of a few I had in mind.
these guys are on point Jen.
if you just want a decent boost and not worry too much about the tranny and clutch, stick with a 50 shot. definitely look to invest in a window switch, digital or otherwise. I'm hoping this kit is a wet kit as well.
Steven what's the difference between the BCPR and BKR? just the cut in the electrode? I've been meaning to ask you since I"m running the BKR7E11's still.
Originally posted by Schizzo97SC2of all the people I was hoping to see this thread, sc2grndsp and Nyce are two of a few I had in mind.
Steven what's the difference between the BCPR and BKR? just the cut in the electrode? I've been meaning to ask you since I"m running the BKR7E11's still.Steven
I can't add much but to just agree with these fuggas^^^^
Stock internals will handle 75 max without damage (unless user error) and 50 is a good safe bet. I sprayed 50 for many months on an engine with 280K and no problem.
As they said, be safe and get a window switch and also use a Wide Open Throttle switch (none of the fast and furious steering wheel button crap). Make sure you use a wet kit, DO NOT use a dry kit, it is much less safe.
Spray is lots of fun for relatively low cost, I can't wait to get mine back on the road [img]{SMILIES_PATH}/icon_twisted.gif[/img]
Originally posted by redturtle98Just to ease every one's mind it is a wet kit.Steven
Originally posted by Plastic FuryI can't add much but to just agree with these fuggas^^^^
Stock internals will handle 75 max without damage (unless user error) and 50 is a good safe bet...
And I am glad to hear you may go nitrous; Kevin is right (sc2grndsp), if you only want to go nitrous, scrap the fuel system conversion and keep the returnless fuel system.
Originally posted by SpoolinSc2And I am glad to hear you may go nitrous; Kevin is right (sc2grndsp), if you only want to go nitrous, scrap the fuel system conversion and keep the returnless fuel system.sigpic
Former owner of the Turtle
(Sold 2017)98 SC2
98 Honda CR-V my dd
Originally posted by SpoolinSc2[Just so you know, 75 is not the "max". The "max" so to say varies from engine to engine based upon the overall health of the entire setup, tune, and amount of nitrous use on a daily based average. Though 75 is a close to "max" for your average tuner, you can go above this on stock internals with the proper tuning/monitoring equipment.
But yes, you are right, you can go more.
Originally posted by Plastic FuryOriginally posted by SpoolinSc2[Just so you know, 75 is not the "max". The "max" so to say varies from engine to engine based upon the overall health of the entire setup, tune, and amount of nitrous use on a daily based average. Though 75 is a close to "max" for your average tuner, you can go above this on stock internals with the proper tuning/monitoring equipment.
