3000-6000?
  • 3000-6000?
    just curious what happens when you spray over 6000?
    i know that below 3000 things tend to be a lil to lean but at 6000 the injectors should be running for all their worth.
    so enlighten me please
    Well at 6000rpm your getting close to fuel cut, which if you hit it spraying will pretty much make something in your engine give up the ghost.
      ^^^ Bingo
      under 3000RPM there isn't enough vaccuum to draw the mixture through, that's why you chance getting a backfire.
      my disarm point is at 6300RPM because of our craptastic rev limiter that kicks in around 6450, otherwise it would go to about 6500.
        ^^^^^HEHE My Rev Limiter is at almost 8000
        hehehe, I never hit it heheehe
        *points at you and laugh* hahahahhahaha
        Nah I only hit mine in the dyno, ONCE
        and B4 u say it
        It doesn't matter that you'res is faster
          well say hypotheticaly there is no rev limiter?
          yeah i knew it was the vacume thing below 3000 idk were my head was at lastnight
            and B4 u say it
            miata right? is it first gen or second? driving a first gen, the limiter was 7600ish, and the power's all gone after 6500-7000.
            resident embarrassment to billy and marc<br />http://shockingcats.ytmnd.com/<br />http://like.ytmnd.com
              then uhh you would keep spraying until your broke your engine.
              without better valve springs i wouldnt rev the engine past 6500 on the ecotec.
                thats being considered when the head is built
                  1st gen w/ the 1.6L ummm I dunno, when I took mine to the dyno
                  (fucked up ignition timing) it kept making HP till redline
                  I usually shift at about 7 and I chirp 2nd so it's all good for me
                  I wanna fix the timing up to something like 14 degrees (maybe a lil bit less)
                  You should tell you're boy in case he doesn't know, stock timing sux u need to advance it and you get a couple of HP to the wheels
                  Free HP = The shit
                    saweet will do
                      okay this is a dumb thread.
                      andy $$$$ can let you do almost anything.
                      Instead of making "dream" threads why not actually go out and do something?
                        hmmm...what about with the auto ecu?...i thought i got rid o the rev limiters?....as u know i have an auto..so woo...lol
                          the question was directed at being used on an Ion Dan, that's why
                            its called research. [img]{SMILIES_PATH}/rolleyes.gif[/img]
                            i was just curious about the effects on the rest of the motor.
                              OMG if we went by that there wouldn't be forums
                              PERIOD NO CAR FORUMS
                              At least his ? was a good one not one of these:
                              Hey guys i'm turboing my car what should I buy?
                              And if you actually READ his ?
                              it went like this
                              BTW: U just got
                              Loading...
