Clutch for an N/A build?
This topic is closed.
  • Clutch for an N/A build?
    here is the build.
    3rd gen block .20 over
    CP pistons 8:5:1
    crower rods
    stage 2 P&P head
    SMS mainfold
    GEO TB (been port mathed to the Manifold)
    light weight Flywheel
    Removed A/C & PS
    Undrive pulleys - Crank, water, and alternator
    Im going to be using this as a daily driver and im thinking about just putting a stock clutch in but would it be better if I went to a stage 2 clutch? would I notice any difference?
    Why such low compression?
      I was gonna ask the same question. That's high boost level compression there.
        The question is really going to be, "how stiff do I want my clutch on my daliy?" Typically the answer is "not very" and the oem clutch ends up being the best clutch per price point. If you plan on using this for some sort of FI build in the future, I would consider a different clutch then, but if you are going DD with it, then I would not worry about most of the stuff on the list mate. If you end up wanting or needing head work, feel free to get in touch with me.
        CSW Tuning or Facebook!
        - Stork
          I love my ACT street disc to death. I will put it in every other Scar I have, no matter how stock (well maybe not a TBI SOHC). The feel is awesome compared to the stocker, IE: you can actually feel where it engages.
            I was initially going to boost this car, but I am not sure now. I don't know if I want to deal with all the hassel of installing the megasquirt and gauges and etc. I was originaly planning on 15 psi for my boost.
              If you aren't planning on tossing some F/I at that thing, I'd honestly sell the fucker and drop a stock longblock in. I've driven a low comp ll0 car before with no boost, and I'd hate to have to do it daily.
              As is though, these guys are right. If it won't see completion, get an OEM clutch.
