high flow cat
  • high flow cat
    just purchased an exhaust, looking at high flow cats. I assume there is some difference between them, is there any one better than another or can anyone explain some differences?
    edit: 2.25"
    99 Saturn Blackberry SL2
    <br />7/17/2006
    The change in diameter is more gradual then a normal cat...resulting is less turbulent flow.
    Iknow there is a 2 catylist and3 catylist cat....wich one you need to keep the o2 happy (ODB2 only), IDK.
      Re: high flow cat
      edit: 2.25"
      Even the stock one is pretty high flowing in comparison to other cars' cats and most of the ones on ebay are too. If you plan to auto-x in the stock or sts classes you are required to use a stock cat or OEM replacement cat in same location. That means stock size and stock or OEM part.
      Personally I think this is the most BS rule in the STS class ruleset. I can put on any header I want and any cat-back exhaust I want as long as it isn't too loud, but I have to use a stock or OEM replacement Cat.....that's just DUMB!!! [img]{SMILIES_PATH}/evil.gif[/img]
        I got mine off of amazon.com for dirt cheap, it is the 2.5" one, but if you are staying N/A just go with the 2.25"
          I bought a Magnaflow carsound cat off of ebay for $45 or $50 shipped. Its recommended by the LS1 community.
          It looks like a stock cat not a straight through round one. Its 2.25" and the model number is 94105.
            Originally posted by 93 Saturn SL2
            94105
            that's the one I got.
              if you dont get that one, SDA has one.
                link to the sda one?
                edit: found, i assume with a 2.25" exhaust i want the 2.25" cat
                <br />7/17/2006
                  [quote="99_SL2"]]
                  you could get the 2.5, but prolly wouldn't be too much of a difference. especially if you have a stock header with the 2" down pipe. i'd say 2.25 would be fine.
                    well im replacing the header also, but the downpipe you cant replace correct?
                    <br />7/17/2006
                      a good header will come with a DP,.
                        obx header comes with teh downpipe?
                        then yes i am also getting a downpipe.
                        2.5 is the same price as the 2.25 any reason to not ge the 2.5?
                        <br />7/17/2006
                          i bought a magnaflow 2.25 for like 55 shipped but i dont know if im goin to use it or not
                          <br /><br />I wont bow to something that I've never seen..........I can't believe in something that doesn't believe in me....I'm not blood of your blood.....I'm no son of your god...I'm have no faith in your faith, still I find salvation<br /><br />[quote author="omgitselvisc"]im vinny's bitch i guess lol[/quote]
                            well then keep me informed over the next couple days.
                            whyd you change your mind?
                            <br />7/17/2006
                              well if i do turbo it in time then im prolly just goin to straight pipe it i think ill use it till im turboed though
