Header paint
  • Header paint
    Just won a 91 header on ebay and I was wondering if you got any tips on how I should prep it before I paint it?
    im just gonna use some high-temp exhaust paint.
    <br /><br />[quote author="bwtucker"]two guys whose avatars are bent rods disscussing what to do with a motor that involves possible breakage can't be a good thing<br />[/quote]
    Re: Header paint
    I bead blasted mine first to get all the rust and crap off it, then used exhaust paint. been 3 years now and still looks good.
      yeah it be best to sandblast it. dupli color high temp stuff seems to work fine, but you want to bake it on meaning stick it in the oven but not an oven you cook with!!!!!!!!
        Agreed on the sandblast, the easiest and most thorough method. I have used a small grinding wheel but it was a royal pita.
        The VHT high temp header stuff is pretty damn good paint as well.
          ok, feel free to tell me this is a dumb question but what exactly is sandblasting?
          I hear about it all the time but up till now, ive always just stuck with a grinding wheel.
            or put your header on after it is near dry and let your car idle for 10 mins...
              actually you want ot do that after it's already dry
                I glass beaded my turbo manifold, and then sprayed the VHT 2000 degree? stuff on there...works great, but the house stinks after you bake it on the oven.
                  +1....that's what I used as well.
