oem header bracket
  • oem header bracket
    I just want to make sure that the oem header bracket bolts straight up to a 93+ car.
    In this pic from qksltwo it looks like there is something blocking the bolts.
    i wish it would have fit on a 98, but i had to make my own.
      That something is the intermediate shaft (which is on ALL S-series saturns) and the proper bracket should bolt right on.
        What DP said, if you have the down pipe and bracket for it, you should have no problems at all.
        Fabbing up one is easy as well.
          The bracket should work on 91-02. I have one bolted to a 2000 engine right now. You just remove the two back bolts on the trans/engine stiffening bracket and install the downpipe bracket there. The bolts go through it.
          - Jeff Silva
          2001 Chevrolet Tahoe Z71 5.3L, Blackbear tune, cranked keys, e-fans, Android head unit
          1997 Dodge Caravan SE 3.3L V6 family hauler
          Vacancy here, need project car
            It's just the angle of the pic, it should work just fine, I had it on a 94.
