I remember the big long thread back on TSN debating whether or not to replace the exhaust cam with another intake cam. I was wondering if anyone ever got around to running a Dyno with and without it. Also it got me wondering why saturn didn't just have two identical cams on all the DOHC motors and save the money it would cost having two different grinds, especially if there is a minor gain using the two intake cams.
Two Intake Cams
Two Intake Cams
-Mike-MN <br />'96 SC2 <br />Check out my website!<br />[img width=350 height=40]http://www.sixthsphere.com/storage/976/stc_banners-oakdog8.jpg[/img]
Tags: None
Originally posted by Ralliart16because saturn doesnt care about performance gains, they are worried about reliability, emissions, etc...
Intake cam for exhaust cam? Higher lift?
higher lift and longer duration. IIRC you set it 180* opposite and then retard one tooth. I'd assume saturn and GM would be cheap about it before they would consider performance at all, meaning one grind for all cams-Mike-MN <br />'96 SC2 <br />Check out my website!<br />[img width=350 height=40]http://www.sixthsphere.com/storage/976/stc_banners-oakdog8.jpg[/img]
Originally posted by andy_wh2000has whoever that did already noticed any mileage changes. obviously it'll give better performance after a tune but will it affect gas mileage negetively?[color=red]-Tyler[/color]<br /><br />2005 Chevy Trailblazer<br />1999 Saturn SL2<br />2002 Suzuki Bandit 1200
natedogg from TSN Buttdyno'd it and said that he noticed minor gians up top, a smoother idle, and said it didn't seem to affect gas mileage much. I'm just wondering if anyone has since gotten their car on a dyno with them-Mike-MN <br />'96 SC2 <br />Check out my website!<br />[img width=350 height=40]http://www.sixthsphere.com/storage/976/stc_banners-oakdog8.jpg[/img]
I belive natedogg was turbo'd-Mike-MN <br />'96 SC2 <br />Check out my website!<br />[img width=350 height=40]http://www.sixthsphere.com/storage/976/stc_banners-oakdog8.jpg[/img]
Originally posted by sl2fastOriginally posted by andy_wh2000has whoever that did already noticed any mileage changes. obviously it'll give better performance after a tune but will it affect gas mileage negetively?
TOM did this on TSN
he had a 92 DOHC and some how found that the ( 91 ) DOHC head come with the funkey intake cam
why I'm pointing out the 1991 DOHC part is he found that only the 91s had that cam ( as far as I can remember )
but you can do this swap with aney ( intake ) cam to gane the added over lap between the intake and exhoust cam
