So after reading the 88mm thread, he got me thinking that this is probably the way to go for bigger pistons for more compression without sacrificing block integrity. Is there anyone here that has or knows someone that has gone this route with N/A in mind?
SMS monster block
SMS monster block
Fixing a Saturn can be like reaching into a bag of scorpions and hoping for the tootsie roll.
AMR coilovers w/pillowball mounts, AMR FTB, AMR RST, Quaife, ACT clutch, HR con rods with JPC max bore pistons, Thermal exhaust, Hotshot header, AEM CAI, and I just want to run around tearing my cloths off, screaming beligerently, and spitting, and twitching, and foaming; because its finally done.Tags: None
getting closer to a square engine will help. Of course, being overbored that much will put you well beyond 100% VE for the originally intended displacement.
Try it out.LSJ powered 1998 Chevy S-10 turbo
what if it did?LSJ powered 1998 Chevy S-10 turbo
variable valve timing isnt much n/a. its the way the intake side is designed. sure variable valve timing increases air flow but isnt impressive n/a unless say the motor is HELLA BUILT! now variable valve timing under boost uuuuuuummmmhhhhmmmm. im not saying vtec, because other vehicles are the same way.Ian---The Fat Ass
Considering the only weak points we ever really had were were diff pin and thin walls; everything else has been well beyond reliable. Yes, it would be a totally different engine. But an engine swap would cost just as much. I'm doing the math in my head..........but I really do think this would cost less then a boosting. The only real jump in price would be pistons and I don't think by much. I could forego a lathed down crankshaft, because I would need the extra metal for reliablility. Guys I think this might the route to go for a true engine. I think we've greatly overlooked the possibilities of this block.
I have to do some more research, I think I'll have to check out some big block forums.
By the way...........I think it's absolutely justifiable to buy that block. You figure you will spend 3k on just the basics of turbo. What's an extra 1k to make it bulletproof? Not much if you ask me. I'm starting this project next month, because I'll have another 1k to buy the block. Watch out for me, because I've just found my keystone to get this project going.
V V T under boost is weak, you have to do sooo much tuning with that shit to get it right. Now the new K series engines by Honda those work f...ing awsome under boost. But like I said I want N/A
What does VE mean???Fixing a Saturn can be like reaching into a bag of scorpions and hoping for the tootsie roll.
Volumetric EfficiencyLSJ powered 1998 Chevy S-10 turbo
Hmmm SDA has their racing intake how do you thing it would fair?Fixing a Saturn can be like reaching into a bag of scorpions and hoping for the tootsie roll.
Originally posted by TimTMore people have snapped rods then broke blocks. Stock rods at best are good for about 200hp. If you go with a monster sized bore you might as well scrap tour intake and TB. You'll never get it to breath.
Tim-6S Resident Mechanical Forensics member #001.
Originally posted by SupraCharged007yea, I would think borderline for stock rods would be right around the 250 mark depending on the tune
That is what I remeber too.[quote author="shortbus"]Stage 2 is great. Its covered by warranty, better fuel economy, the eaton screams louder so deer wont jump onto the road, it makes girls get wet, and the emissions produced will not kill songbirds or melt glaciers.[/quote]<br />[quote author="retardpartol"]...who is sober and noton any kind of intoxication whether is be ibuprophin[/quote]<br />LSJ phun
