SS exhaust web site??
  • SS exhaust web site??
    I'm going to build a SS exhaust for the car seeing as I need one. Any web sites out there with prebends,tubing , resanators cats etx. out there.
    Thanks
    Tim
    Go aluminized and spray the weldds with hijgh temp paint. Much cheaper, and same results.
      agreed your in the south. rust it something us northern ppl have to worry about every 5 years lol
        No I'm in south Louisiana were the humidity is worst then road salt. I'm going SS. Plus too much extra prep when working with aluminized.
        Tim
          Like what...you don't have to back purge the inside of the aluminized pipe like with stainless. The most you should do it wire wheel bruch the aluminized coating off, which you do that anyway to clean dingle berries off from cutting the pipe.
          If you justmig it, you can get full pentration, and don't have to even clean the coating off, it burns/melts off before you steel melts.
            not to mention you can even use a stick welder on the aluminized. It's more difficult to weld stainless with stick. I get stuff from http://store.racing-solutions.org/index.html Pretty cheap kits.
            [quote author="S.Bretz"]Racing a SOHC saturn is like have a child with down syndrom. It technically shouldn't happen, but ever once in awhile some shit just gets fucked up and you have a 21st pair with 3 chromosomes.[/quote]
              Try looking at http://www.summitracing.com or http://www.magnaflow.com or http://www.borla.com
