Hey how hard would it be to change the head from SOHC to DOHc and i need to know what parts i would have to get.
Head change!!
Originally posted by brokenheadz2003sarcasm.........
anywho the sohc piston and rod combo do create lower compression in the first gens and thats what i was basing my info onSaturnSeries.net Owner
Originally posted by brokenheadz2003low compression = poor performance yeah.....it will run like crap compared to what he is probly thinking it will run like
the 91-98 I believe have the super dished pistons, 91-02 had mild dished (it might have been 91-97 and 98-02, I tend to confuse that bastard year)
the reason the pistons are dished is because the SOHC head has almost a flat combustion chamber as opposed to the pent roof of the DOHC head, so they needed to make room somewhere else. a lot of guys will run that combo with boost since compression is down to around 8.5 or maybe a few points higher as opposed to the stock 9.5:1 CR.
I've seen a few people do this without boost and they performed alright, but if you want to possibly run low boost on this engine later on I'd take this route for sure.
Originally posted by The ShaolinJesusfrigginchrist, do a search.
YES, you can do it.
I just did it.
NO, you should not do it. It's 100x easier to buy a new car, or drop a whole engine in.
Here's a list of some of the stuff you're going to need:
Head
Intake manifold
Exhaust manifold/downpipe
Fuel rail
Injectors
Coolant lines
Cams
Cam bolts
Timing chain cover
Timing chain kit
Oil pan tie plate and pickup tube
Probably lots of other random crap. Just get a donor car, or a complete motor. It sounds like you have absolutely no idea how a car works, so just buy a new one.
Originally posted by Schizzo97SC2Originally posted by Jeremy97sc99+ sohc pistons are the same as twin cam pistons.
ONly 91-98 sock pistons have a dish.
I always second guess that they started in 98 since it's the second bastard year like 95. bah.
Originally posted by brokenheadz2003low compression = poor performance yeah.....it will run like crap compared to what he is probly thinking it will run likeSaturnSeries.net Owner
