Planning on 14:1 comp.
2000+block and girdle
99-02 Crank w/ scat rods from SDA
91-94 Pistons (Sealed Power Stock Replacement Hypers)
92 Head, headers, and new replacement flat-faced valves and springs
port and polish job to the head with a .040 deck shave
97 Intake Manifold and fuel system w/91-94 injectors
98-99 axles (will they fit an older transmission? or do I interchange the differentials, replace trans?)
Geo Storm GSi TB (56mm with a fresh taper at the mouth and Manifold inlet.)
Rear Disc Brake conversion
SDA Dogbones and TAM + insert Combo
Fidanza Flywheel and ACT 6puk unsprung hub
CCG underdrive pullies.
P/S and A/C removal
Custom Shifter work (reducing throw by 45% est.)
QKSLTWO 3'' CAI
Phantom Grip LSD conversion
port matching to headers and intake manifold
Apex-i SAFC II w/WBO2
P/S and A/C removal
QKSLTWO 3'' CAI
