i just got one and i was told since its molded it doesn't need any sealant, just make sure that the old one is completely scraped out, but then someone else told me i still need to put sealant on the cover then the gasket. how are these gaskets supposed to be installed?
felpro molded valve cover gasket install
You're not supposed to need any sealant... But I find that to be BS..
I usually put the gasket into the cover, run a small bead across the head sealing surface, smear it on and then put it on...07 Redline w/ stuff.<br /><br />89 Civic hatch w/o stuff.<br /><br />96 SL2 that dont need stuff.
If you havea metal cover, use a thin bead on the cover and then stick the gasket to the cover. The silicone acts to "glue" the pre-made peice into place as you turn the cover over. Also like said before, a thin smear around the head surface is a REALLY good idea... around the plug well holes too. Also, but a dab right on the head/timing cover union.-6S Resident Mechanical Forensics member #001.
Yep...listen to these guys. I had a major oil leak in the #1 spark plug tube...cleaned most of it out and put new plugs in. Then I used Seafoam (not sure that's the best cleaner to use but it was handy) to clean the head surface and get out as much oil and sludge as I could as well as whatever oily mess was in the groove of the valve cover.
Then I took the gasket and installed it in the cover...then took some Permatex Right Stuff black gasket maker and put a good bead around every part of the mating surface. I wasnt even stingy with it...some spots accidentally got a little thicker than I had wanted, but as long as it doesnt interfere with any moving parts it should be ok. Then I quickly got the cover on and tightened down...hasnt leaked a drop since.1997 Silver SC2 Coupe
Originally posted by therealm0rh0usbut it will never come off againOriginally posted by ECOtec GodsConsider this: 800 hp is a lot on a 2.0L motor. With 750hp, three-quarters of a thousand you're basically dealing with 6.14 hp per cubic inch. Pressures and stresses of all kinds thermal and mechanical loading across the board escalate to extreme levels. A Chevrolet 5.7-liter LS1 V8 with this much specific power (horsepower per cubic inch) would be making 2,137 hp
sense we answered his question ill deviate from topic
Originally posted by therealm0rh0usyour avatar scares meOriginally posted by ECOtec GodsConsider this: 800 hp is a lot on a 2.0L motor. With 750hp, three-quarters of a thousand you're basically dealing with 6.14 hp per cubic inch. Pressures and stresses of all kinds thermal and mechanical loading across the board escalate to extreme levels. A Chevrolet 5.7-liter LS1 V8 with this much specific power (horsepower per cubic inch) would be making 2,137 hp
It might take some work, but I'm sure a putty knife and a rubber mallet will crack that seal.
All I care about at the moment is that its a way better seal than what I had bone stock...which is to say there was no seal. I had a little bit of oil puking out of every side of the head and it almost filled up one plug tube. Now at least the front and back and driver/passenger sides of the head are clear of oily sludge. Plus the plugs are still bone dry as they should be. Looks a lot nicer than the mess I had before.1997 Silver SC2 Coupe
I must be in the minority but I have used a little rtv and I have done it without any and both haven't leaked. As long as the surface is clean and your using the molded gasket you shouldn't need any except for where the TCC, head, and VC meet.
-Allan.-Allan
Originally posted by AC66Broncosense we answered his question ill deviate from topic
Originally posted by therealm0rh0usyour avatar scares mesigpic-VOLVO 745T 175K MBC ...
of course its better to not leak oil
i bought the saturn oem seal and it pushed out and dumped oil everywhere so i used lots of sealer on it and it will probably take some work to break it but its not leakingsigpic-VOLVO 745T 175K MBC ...
