am i the only one wit a messed up sunrrof that just doesnt want to open...The motor is fine and the assembly itself is fine but it seems that its binding up whenever i try to open it...i took it down 3 times to see if i can fix it but i cant seem to be able to...any tips or advice would help....
Sunroof Problems
i can tell you what ever you want to know about them since i and many many others have had to deal with the shitty sunroof tracs. in short they need lube if it isn't already broken. most people don't do the proper maintance on the sunroof which leads to failure.2007 chevy classic 2500hd 4x4 duramax
the motor seems to be binding up.. the glass doesnt even move an inch..it really bad...i dont wanna paid some sunroof guy to fix if i can save that money on something else...u know of any possible ieas on what to do or waht to lube up??Dont hate the driver...Hate the Saturn
Originally posted by dream36realmssunroofdoctor .com or something to that effect you can order the whole thign for cheapsigpic-VOLVO 745T 175K MBC ...
i had a broken arm on my sunroof. you can actually dismantel the sunroof and swap it out with an arm from a junkyard gimmick pretty easy. i am pretty sure they don't sell the replacement parts at the dealer.2007 chevy classic 2500hd 4x4 duramax
you have to remove sunroof glass first.
then you will find this very tiny pin about in the middle of the arm. you remove that . and then you have to remove the boltand plate that is closest to the windshield that is connected to the track.
you then use the motor to bring it back into the closed position where you just have to work the arm out of the channel. steps to install is in reverse.
remember to pay close attention to where the everything is located and how it fits in under that plate you had to remove. this is what locks in the screw drive for the sunroof.
yo are doing most of this from the outside of the car and just take your time.2007 chevy classic 2500hd 4x4 duramax
