Categories
article_tags
There are no tags yet.
Latest Articles
by SC2SickThere are a couple of options for lowering your 1991-2002 Saturn SL SL1 SL2 SC SC1 SC2 SW SW1 SW2 SWP models
Lowering spring options:...-
Channel: How To: S-Series
11-14-2019, 07:45 PM -
by SC2SickA "Deebs" build is a popular, all Saturn original parts, way to make a performance engine for the Saturn S-Series platform. These parts are easy to source parts that you could easily obtain from a junkyard or salvage yard ( car-part.com ) that should net modest performance gains without too much difficulty. This can replace a Single Cam ( SOHC ) or be used in place of the later generation Twin Cam ( DOHC ) with minimal additional parts. Generally a computer swap ( see PCM/BCM security relearn...
01-17-2017, 11:29 AM -
Writeup courtesy of Megan SC2
(*please trace the leads with a multi-meter. just trying my untested leads could damage your control board.) My 2002 SC2 power window switches have stopped working, AGAIN! I've cleaned the contacts before which helped but was never a great solution. I never had a way to restore the eroded metal on the contacts, and without fixing the contacts cleaning them was pointless. And who wants to take these things apart again? NOT ME! ...-
09-25-2015, 02:45 PM -
11-15-2010, 06:11 PM -
10-01-2010, 12:50 PM -
