How To: S-Series
Sorry, you are not authorized to view this page
article_tags
There are no tags yet.
Latest Articles
  • Saturn Coilovers ( Subaru coilover mod )
    by SC2Sick
    11-14-2019, 08:02 PM
  • Saturn S-series Suspension - Lowering Springs
    by SC2Sick
    There are a couple of options for lowering your 1991-2002 Saturn SL SL1 SL2 SC SC1 SC2 SW SW1 SW2 SWP models
    Lowering spring options:...
    11-14-2019, 07:45 PM
  • Deebs Build Saturn LL0 engine
    by SC2Sick
    A "Deebs" build is a popular, all Saturn original parts, way to make a performance engine for the Saturn S-Series platform. These parts are easy to source parts that you could easily obtain from a junkyard or salvage yard ( car-part.com ) that should net modest performance gains without too much difficulty. This can replace a Single Cam ( SOHC ) or be used in place of the later generation Twin Cam ( DOHC ) with minimal additional parts. Generally a computer swap ( see PCM/BCM security relearn...
    01-17-2017, 11:29 AM
  • 3rd Gen SC2 SL2 Universal Window Switch Installation Guide
    slipstreamconversion
    Northern Plastic
    by slipstreamconversion
    Writeup courtesy of Megan SC2
    (*please trace the leads with a multi-meter. just trying my untested leads could damage your control board.) My 2002 SC2 power window switches have stopped working, AGAIN! I've cleaned the contacts before which helped but was never a great solution. I never had a way to restore the eroded metal on the contacts, and without fixing the contacts cleaning them was pointless. And who wants to take these things apart again? NOT ME! ...
    09-25-2015, 02:45 PM
  • Removing Cams Without Removing Timing Chain
    SixthSphere.com
    6S Bot
    by SixthSphere.com
    11-15-2010, 06:11 PM
  • S Series Aftermarket Spring Rates
    SixthSphere.com
    6S Bot
    by SixthSphere.com
    10-01-2010, 12:50 PM
