Spring Rates:
OEM Springs: ............................ 126 lb/in Front, 129 lb/in Rear
H&R Race (1.4"F, 1.3"R):.............. 310 lb/in Front, 250 lb/in Rear
H&R Sport (1.4"F, 1.3"R):............. 205 lb/in Front, 195 lb/in Rear
Eibach Pro Kit (1.3"F, 1.1"R):........ 149 lb/in Front, 91-159 lb/in Rear
Progress Group (1.8"):................. 200 lb/in Front, 170 lb/in Rear
Progress Group (1.3"):................. 156 lb/in Front, 150 lb/in Rear
Sprint (2.0"):............................. 200 lb/in Front, 140 lb/in Rear
Sprint Extreme(2.5"): .................. 200 lb/in Front, 140 lb/in Rear
Suspension Techniques (1.4"):...... 157 lb/in Front, 109-155 lb/in Rear
Struts:
KYB GR-2 front: 30% stiffer than stock
KYB GR-2 rear: same as stock
ST front:*
ST rear:*
*No one knows any real specifics on the ST struts as far as dampening goes. But the general consensus is that they are stiffer than KYB GR-2s.
S Series Aftermarket Spring Rates
Created by:
SixthSphere.com
- Published: 10-04-2010, 11:45 PM
- 2 comments
Categories
article_tags
There are no tags yet.
Latest Articles
by SC2SickThere are a couple of options for lowering your 1991-2002 Saturn SL SL1 SL2 SC SC1 SC2 SW SW1 SW2 SWP models
Lowering spring options:...-
Channel: How To: S-Series
11-14-2019, 07:45 PM -
by SC2SickA "Deebs" build is a popular, all Saturn original parts, way to make a performance engine for the Saturn S-Series platform. These parts are easy to source parts that you could easily obtain from a junkyard or salvage yard ( car-part.com ) that should net modest performance gains without too much difficulty. This can replace a Single Cam ( SOHC ) or be used in place of the later generation Twin Cam ( DOHC ) with minimal additional parts. Generally a computer swap ( see PCM/BCM security relearn...
01-17-2017, 11:29 AM -
Writeup courtesy of Megan SC2
(*please trace the leads with a multi-meter. just trying my untested leads could damage your control board.) My 2002 SC2 power window switches have stopped working, AGAIN! I've cleaned the contacts before which helped but was never a great solution. I never had a way to restore the eroded metal on the contacts, and without fixing the contacts cleaning them was pointless. And who wants to take these things apart again? NOT ME! ...-
09-25-2015, 02:45 PM -
11-15-2010, 06:11 PM -
10-01-2010, 12:50 PM -
Some of the stock springs have slightly higher rates than what is generally accepted, and there are a few different ones to choose from.
All have a tangential end and a pigtail end -- I mention this because 'tangential' end springs can indeed be cut, resulting in both lowering and a (counterintuitive) increase in spring rate... which might be useful.
I ordered some of the Rockwell '681s on closeout, and the tangential end sure looks like a 'square' end to me (the last 1/2 turn on the helix on that end is bent back a little -- hard to describe, but it's not uniform with the neighboring turns) Bottom line: I'm not sure these can be cut.
BTW, regarding cutting springs: https://www.eatondetroitspring.com/c...-calculations/ is a good starting place. There are many spring calculators online.
The following data is from http://www.moog-suspension-parts.com...il_springs.asp with my added comments. The Moog part numbers mostly cross to Rockwell, substitute RV- as a prefix, e.g. RV662. Other aftermarket manufacturers of 'stock' replacement parts seem to be out of the game at this point, but the part numbers are similar.
Some of these are variable rate, and I have no idea what the actual numbers are versus deflection. I have a friend (ME prof) at a local university... will see if I can get some time on his Instron machines for testing.
These data are confirmed with cross references from Rock Auto, classiccarsprings.com, and other sites. Hopefully I typed it all in right. The first two are fronts, the rest are rears.
